Hi all,
I should disable the ability to create a new relationship when an Item is in a certain state.
For example:
I have an Item Document with an relation to Item File.
When the user create a new document (state document = New) he can create a new relationship with an Item File.
If the Document is promoted to another state (Check) the user can only modified the property of Document but he can't modify a relationship (add, remove, edit).
I found more example to hide a Tab Relationship, but i want to show this tab in Readonly mode.
For your use case, it may be desirable to programmatically set the permissions of these relationship items in an onAfterPromote server event on the parent itemtype. This way, you use the built-in aras permission model to disable new relationships from being added or deleted based on the parent's life cycle state.
While the post below doesn't cover this exact use case, it does provide an example on how to programmatically update an item's permissions which you can modify to fit your needs.
http://community.aras.com/en/knowledgebase/permissions-based-item-property-values/
_____________________________________
