After a bit of troubleshooting i updated VaultServerConfig.xml with https (instead of http) for AppServerURL:
<?xml version="1.0" encoding="UTF-8"?>
<VaultServer>
<AppServerURL>localhost/.../AppServerURL>
<LocalPath>C:\Aras\Vault\</LocalPath>
<login_name>vadmin</login_name>
<name>Default</name>
<password>vadmin</password>
<version>11.0.0</version>
</VaultServer>
This let me get a bit farther where i get another error:
2018-01-16 11-48-08 Exception In Background Thread
Exception Message: The underlying connection was closed: Could not establish trust relationship for the SSL/TLS secure channel.
Stack Trace:
at System.Net.HttpWebRequest.EndGetRequestStream(IAsyncResult asyncResult, TransportContext& context)
at System.Net.HttpWebRequest.EndGetRequestStream(IAsyncResult asyncResult)
at Aras.Server.Vault.Utils.UtilsImplementation.EndRequestStreamCallback(IAsyncResult asyncResult) in D:\Builds\Innovator\6549-RELS11-0-SP9\Innovator.git\Innovator\CompilableCode\Aras.Server.Vault\Utils\UtilsImplementation.cs:line 254
at System.Net.LazyAsyncResult.Complete(IntPtr userToken)
at System.Threading.ExecutionContext.RunInternal(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx)
at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx)
at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state)
at System.Net.ContextAwareResult.Complete(IntPtr userToken)
at System.Net.LazyAsyncResult.ProtectedInvokeCallback(Object result, IntPtr userToken)
at System.Net.HttpWebRequest.SetResponse(Exception E)
at System.Net.ConnectStream.ProcessWriteCallDone(ConnectionReturnResult returnResult)
at System.Net.ConnectStream.CallDone(ConnectionReturnResult returnResult)
at System.Net.ConnectStream.IOError(Exception exception, Boolean willThrow)
at System.Net.ConnectStream.WriteHeadersCallback(IAsyncResult ar)
at System.Net.TlsStream.ResumeIOWorker(Object result)
at System.Net.TlsStream.WakeupPendingIO(IAsyncResult ar)
at System.Net.Security.SslState.FinishHandshake(Exception e, AsyncProtocolRequest asyncRequest)
at System.Net.Security.SslState.ReadFrameCallback(AsyncProtocolRequest asyncRequest)
at System.Net.AsyncProtocolRequest.CompleteRequest(Int32 result)
at System.Net.FixedSizeReader.CheckCompletionBeforeNextRead(Int32 bytes)
at System.Net.FixedSizeReader.ReadCallback(IAsyncResult transportResult)
at System.Net.Sockets.BaseOverlappedAsyncResult.CompletionPortCallback(UInt32 errorCode, UInt32 numBytes, NativeOverlapped* nativeOverlapped)
at System.Threading._IOCompletionCallback.PerformIOCompletionCallback(UInt32 errorCode, UInt32 numBytes, NativeOverlapped* pOVERLAP)
I thought maybe i had to install the ssl cert in the trusted certificate on the server itself but no luck. Any ideas?
