The Console Upgrade Tool is a command line version of both the Export Tool and Import Tool described above. The command line parameters can be obtained by typing ‘/?’ as the command line parameter. Required Parameters : server=url server's URL (e.g. server=localhost/InnovatorServer) database=db database's name (e.g. database=dbWithoutSolution) login=uname user's login (e.g. login=root) NOTE: login must have root or admin privileges password=pw user's password (e.g. password=xxxx ) release=rel release's name used by import only (e.g. release=rel11.0) mfFile=path explicit path to .mf file (Not required for export. Default behavior is “export all”) Optional Parameters : import import or export (by default export) merge used by import only (by default uses non-merge option) fastmode used by import only (by default uses thorough mode that provides more through verification of the applied AML) verbose used by import and export (by default uses non-verbose) dir=d1 export: output directory import: location of the manifest file NOTE: the specified path must exist. If the parameter is not specified at all, user is prompted for the path log=logpath full path to the log file. If specified file already exists it's appended. description=desc release description used by import only (e.g description="SolutionsUpgrade") vlog save the resulting log file on the vault (don't save if the argument wasn't specified) level=n request attribute 'level' that is used for non-dictionary item types (used by export only) default: level=1Hope this helps! Eli
Canwe do deployment in ARAS without bringing down the application?
