With the upgrade to SP12 theweb services configuration in the menu went missing. Where can I find it or is it disabled by design? Can anyone shed some light?
addition of web service fails with the same error as it failed with SP9.
Event handler failed with message: TypeError: window.parent.frames.tearoff_menu is undefined [function onformpopulated$user$handler(e) { try { if (onformpopulated1(e) === false) return false; } catch (exp) { aras.AlertError(aras.getResource('', 'ui_methods_ex.event_handler_failed'), aras.getResource('', 'ui_methods_ex.event_handler_failure_msg', exp.description ? exp.description : (exp + ' [' +arguments.callee.toString()+ ']')), aras.getResource('','common.client_side_err')); return false; } }]
