Onchange event in form field event method not running(SP12)
Former Member
Former Member
After upgrading to sp12 I have found a bug that does not work if the field type of the form is of type Item or class structure and the event of the linked method is Onchange. When I think about it, it seems that when I check the item and check it, the cursor does not exist in the corresponding filed. I want to know if it is a bug or if I run it wrong.
  • Hi jing9, I am able to reproduce the behavior you are seeing. This behavior is being reviewed for a fix in a future release of Aras Innovator. In the meantime, you should still see the OnChange event fire if you type the classification into the field and/or select it from the type-ahead drop-down. Eli
