Version 12 Bugs
Former Member
Former Member
  1. Onchange Function Error in Form Field EventI have found a bug that does not work if the field type of the form is of type Item or class structure and the event of the linked method is Onchange. When I think about it, it seems that when I check the item and check it, the cursor does not exist in the corresponding filed.
  2. Dialog Date Error on Search Screen
Screen does not pop up when Dialog Date (created_on, modified_on ..) is clicked on search screen I've checked for errors that occur depending on the size of the browser window. Dialog Date is an error in the part of the script that is responsible for the position when clicked. Apart from this bug, there seem to be a lot of small errors and bugs. Perhaps you will need a patch before you release the next release.
