is there a way to fulfill a dropdown list when the form is loaded with values that can be found in an ItemType field?
I don't want to use the item as a data source.
Catalin,
Good day. I'm not exactly sure what you are asking for with this list. It sounds like you want a dynamic dropdown list based on another field in the form, is this correct?
good day to you too Nathan,
yes, I want a dynamic dropdown list, but the field is not present in the form.
You would add a normal dropdown list to the form. Making the list dynamic involves a method. I have not created one yet, but there are several posts about them. Search for Dynamic List. I saw one post that mentions there is code for it in Programmers Guide 12.0 "7.32 How to Create a Dynamic List". I hope this helps.
