Good day. I added a list property to a few ItemTypes with a default value (itemtype, default value is the ItemType ID). When I create an entry the field is populated and identified correctly. When I try to update other entries using AML (Nash or Batchloader) the field has the correct information, but it is not recognized when I search the field.
Example:
DEMO-14
- this is the newly created entry
DEMO_PDF
- crated previously to the itemtype property being added
I used Nash (and Batchloader to make sure) to update the property to the ItemType's ID. When I perform a 'get' action the fields display the exact same information. When I perform an Advanced Search, select the field, and select the appropriate Label from the list, only DEMO-14 is returned.
I'm not sure what I am missing with this. Thank you for the help.
