Good day all. I have a Class Structure called TO in my Document ItemType, Aras 11 SP10. This classification has an assigned form for it. I modified the labs_HideTabs method to hide the tabs. I need to hide the Files tab if the TO classification is not Current. I have been able to make this work by adding an if statement at the start of the hideTabs function checking for is_current = 0. I was able to make this work when the Method is attached to the default Document form, but it will not work when attached to the Document_TO form associated with the TO classification. It doesn't work even without the if statement.
Both Document and Document_TO forms are set to Default.
Any help would be appreciated. Thank you.
