Screen switching method according to classification
Former Member
Former Member
I want to know how to switch screens based on classification For example, a part with multiple views exists Each view is separated by classification. When you create a part, you want to switch to the appropriate view when you select classification Is there a similar function?
  • Hello, In the Views tab on the ItemType, you should see a column called Classification. You can set multiple Default forms and assign them to different classifications using this column. When you open an item with this classification, you will see the class-specific form instead. Additionally, the form should automatically update to the class-specific form after you edit the classification property. Chris
