Hi, hopefully someone can help me.
I have created an html script in ..\Client\Solutions\PLM\scripts\Changes ( I just copy and paste from an existing one and changed the relationship type)
But when I got to view the relationship it gives me a "File not found page" meanwhile, if I use the one that existed before, it works, only that this is not the item type I want to pull.
Anything else I need to do?
Thx
The question is what you are trying to do? Changes is hard coded and very customize page. To show "Reverse Lookup for relationships " grid you need to use the one used in "Manufacturer Part Part" Relationship and not Changes.
If you want to add your own ItemType in Changes grid you need to update the code of the Changes.html
HI Zahar, thank you for your response. Yes I am trying to set up Reverse Lookup for relationships. However when I use an existing html template it gives me a "page not found" I tried to use an existing copy of Manufactured parts one as well like you suggested and got the same error. Where can I find the hard coded"Changes template? or how do I make the manufactured parts one work for me?
