Technical Documentation - Header & Footer on each page
I am hoping someone may have some help on adding a header and footer that when published to PDF would be on each and every page.
I have added the Header and Footer to the schema and can clearly see them on the PDF but the Header only appears on Page 1 and the footer on the very last page.
Would this be a Prince XML configuration?
  • No it´s not Prince XML. The print design is solely based on the "Document Style" stylesheet. Aras official samples don´t cover much of the daily common use cases. So you literally have to start from the scratch.
    I don´t want to share my complete stylesheet cause I spend 3 month for perfection. But as far as I see, I used the classic "page" section properties to style the header and footer when printing:
    @page {
    size:A4 portrait;
    @bottom {
      content: "Copyright © PLM Underground" ;
      font-family: 'Lato', sans-serif;
      color: red;
    @bottom-right {
      content: "Page " counter(page) " of " counter(pages);
  • Thanks Angela.  That put me on the right highway at least.  The documentation is pretty abysmal for this solution.
