Hi expert,
I need to create three tabs in problem report.
In each tabs, I also need to create many text fields(combo type, list type and so on) for a user to enter.
Would you help how to add tabs in problem report?
Thank you so ~~~ much.
Hi Joseph,
The tabs visible from an item's form represent the Relationships from that ItemType. You can add additional tabs by following the steps below.
Log in to Innovator as an admin
In the Table of Contents, navigate to Administration > ItemTypes
Create a new ItemType
Add the properties that you want users to see from the PR relationship tab
Give a name to this ItemType appropriate to the details in this tab
Save the ItemType
Repeat Step 3 for all of the tabs you want to add to the PR ItemType
Search for the PR ItemType and open it
Navigate to the RelationshipTypes relationship tab
You should see just the PR File relationship by default
Select Pick Related and add a new RelationshipType
Search for and select the ItemType you created in Step 3
Repeat Step 7 for all of the ItemTypes you created in Step 3
Save the PR ItemType
After following the steps above, you should see your new tabs in the PR form.
