How to get values in XSLT sheet in Reports using method
Former Member
Former Member
Hi community, I'm working on one report generation where I need to use the 'where used' feature . So I created a method which in which I use SQL query to get my result But with the following code I can get XML containing my desired output only. I'm stucked how to access that (source_id) value in sheet now other part_no and name I can get in report. Here is my code: var aras = new top.Innovator(); var ItemId = this.getID(); var qryItem = new Item(" Part","get"); qryItem.setProperty("id",ItemId); //qryItem.setAttribute("select","part_number,revision,name"); var BPItem = qryItem.apply(); if (BPItem.isError()) return top.aras.getResource("Baxter Part", "pr_methods.save_item_first"); var baxter_part_number = BPItem.getProperty("part_number"); projectItem2 = BPItem.node.appendChild(BPItem.node.ownerDocument.createElement("Relationships")); var sql = " SELECT pb.SOURCE_ID,pb.related_id from innovator.[PART_BOM] pb INNER join innovator.[PART] smp on smp.ID=pb.RELATED_ID where smp.ID ='"+ItemId+"'" ; var tmpDom = aras.newXMLDocument(); var res = aras.applySQL(sql); tmpDom.loadXML(res); var allAct = tmpDom.selectNodes("//Item/source_id"); for (var i=0;i<allAct.length;i++) { var curAct = allAct[i]; var source_id = curAct.appendChild(curAct.ownerDocument.createElement("source_id")); source_id.setAttribute("select","source_id"); } var report = aras.getItemByKeyedName("Report"," Where Used"); var style = report.getProperty("xsl_stylesheet"); var html = BPItem.applyStylesheet(style,"text"); return html;
