onBeforePromote: how to take the id value?
Hello, I have created a method in c#, in which I take the ID value and do some things.
The fact is that if I put the method in onBeforePromote, it gets a null value, I have tried it in 3 possible ways. The strange thing is that if I put that method in another event, like , it takes the ID value correctly.
Innovator innovator = this.getInnovator();
var id=this.getID();
var OrdenID1 = this.getProperty("id");
var OrdenID2 = document.thisItem.getProperty("id");
//var OrdenID = this.getProperty("id");
//string StateOF = this.getProperty("state","");
//string EstadoOF = this.getProperty("estado_cv","");
return innovator.newError("AA " + id + "BB "+OrdenID1 + "CC "+ OrdenID2);
  • Hi,
    there is not id when using onBeforePromote. Throw an error message just with "this" and you will see.
    It only contains an idlist:
    // Get the Items(s) affected by this promotion
    string idlist = this.getAttribute("idlist");
    // Get items by idlist
    Item xy= inn.newItem("xy", "get");
    xy.setAttribute("idlist", idlist);
    xy.setAttribute("select","xy");
    xy= xy.apply();
    // Prevent execution of code if more than one items was selected (if you want this behavior...)
    int itemCount = xy.getItemCount();
    if (itemCount > 1)
      return inn.newError("This action only works for one item...");
    onBeforePromote is not my favourite kind of event. If you can achieve the same behavior with a LifeCycle pre Method, better use this one!
    Bye
