Hello everyone,
Here is a code snippet to retrieve all identities in a identity (group) recursively. As I faced this requirement multiple times, and Innovator not having a standard function for it, I decided to create it myself.
//**************************************************************************************** // [AUTHOR]: SOFTWERK: D. Theoden // [CREATED ON]: 2024-01-18 // [METHOD]: aer_get_identities_in_group.cs // --------------------------------------------------------------------------------------- // [DESCRIPTION]: // Generic, reusable code to get all users in a group. Implements trick to use functions // inside Aras Innovator server methods. // --------------------------------------------------------------------------------------- // [CHANGES]: // REF NO DATE WHO DETAIL // #001 2024-01-22 D. Theoden Initial version. //**************************************************************************************** // Define parameters Item item = this; Innovator inn = item.getInnovator(); List<string> userIdentities = new List<string>(); Item initialIdentity = inn.getItemById("Identity", "804E11705E1D4E98AEBBDB8E9AFC0B7C"); // Your existing logic to get a (group) identity ProcessIdentity(initialIdentity, inn, userIdentities); // Rest of your logic here. All recursively found identities are now stored in userIdentites array. return this; } // Allow functions in server methods Part A: extra curly brace. This is NOT a mistake. // Function to recursively process identities and add unique users to the list void ProcessIdentity(Item identity, Innovator inn, List<string> userIdentities) { if (identity.getProperty("is_alias", "") == "1") { // Add user identity if it's unique string userId = identity.getID(); if (!userIdentities.Contains(userId)) { userIdentities.Add(userId); } } else { // Process group members Item groupMembers = inn.applyAML("<AML><Item type='Member' action='get' select='related_id'><related_id><Item type='Identity' action='get'></Item></related_id><source_id>" + identity.getID() + "</source_id></Item></AML>"); int memberCount = groupMembers.getItemCount(); for (int j = 0; j < memberCount; j++) { Item member = groupMembers.getItemByIndex(j); Item memberIdentity = member.getRelatedItem(); ProcessIdentity(memberIdentity, inn, userIdentities); } } } // Any more functions of your own... void enableFunctionsInMethods() { // Allow functions in server methods Part B: opening dummy method. This is NOT a mistake.
I hope this saves you some time too. All the best from Almelo.
Daan
