Hi
I make it but with button with event on click with this code :
var partItem = innovator.newItem("result4","get");
var t4id = document.thisItem.getProperty("t4id");
var t4date = document.thisItem.getProperty("t4date");
var t4name = document.thisItem.getProperty("t4name");
var t4comment = document.thisItem.getProperty("t4comment");
console.log(t4id);
console.log(t4date);
console.log(t4name);
console.log(t4comment);
getFieldByName("text0").getElementsByTagName("input")[0].value=t4id;
getFieldByName("text1").getElementsByTagName("input")[0].value=t4date;
getFieldByName("text2").getElementsByTagName("input")[0].value=t4name;
getFieldByName("text3").getElementsByTagName("input")[0].value=t4comment;
var t5button = getFieldByName("Update");
var lockstatus=document.thisItem.fetchLockStatus();
if (lockstatus===0) {
console.log("the item is locked");
t5button.getElementsByTagName("input")[0].disabled = true;
else
t5button.getElementsByTagName("input")[0].disabled = false;
but i want make the changes with out button , i want with save , unlock and close button ?
Maybe this one works:
parent.onSaveUnlockAndExitCommand(); oronSaveUnlockAndExitCommand();
The File formtool_window.js in the codetree gives a good overview of these Form functions.
It depends on your usecase. E.g. you have some "Do something" button in your Item-Form that triggers an "onClick" Javascript Method. Than you can add this code at the end of the Method.
Hi thank you for your answer .
I added this command , but the changes not saved , the code is :
var inn = aras.IomInnovator;
var t5id = getFieldByName("text0").getElementsByTagName("input")[0].value;
var t5date = getFieldByName("text1").getElementsByTagName("input")[0].value;
var t5name = getFieldByName("text2").getElementsByTagName("input")[0].value;
var t5comment = getFieldByName("text3").getElementsByTagName("input")[0].value;
var t5button = getFieldByName("Update").getElementsByTagName("input")[0].value;
var partItem = innovator.newItem("result4","edit");
var id = document.thisItem.getProperty("id");
partItem.setID(id);
partItem.setProperty("t4id", t5id);
partItem.setProperty("t4date", t5date);
partItem.setProperty("t4name", t5name);
partItem.setProperty("t4comment", t5comment);
partItem.apply();
partItem.lockItem();
console.log(id);
How many ItemTypes are involved in this usecase?
parent.onSaveUnlockAndExitCommand() will only save your current context Item, not your Result4 Item.
As far as I understand your code you want to change a "Result4" Item from in the Form of another ItemType. Is this correct?
Why do you want to lock and unlock your Item after partItem.apply()?
