I am a newby to ARAS, so I think I am missing something fundamentally.
I would like to launch a JS based method from a button on a form, which should then open a modal form.
I am getting this error:
"Event handler failed with message: ReferenceError: me is not defined
This is in the line where I am trying to get the new form with the statement:
var fetchForm = me.getInnovator().newItem("Form","get");
I am suspecting that the error is lying with the Item Query on the associated Action calling the method.......
This is still using the default <Item type="{@type...........etc
Riaan
Ok, thanks I have figured it out myself.
If you aren't launching it from an Object then you should create a new Innovator object
var myInnovator = new Innovator();
and then the rest...
var fetchForm = myInnovator.newItem("Form","get");
etc
