I’m receiving errors with Ara.
IOMLogin.aspx Either IOMLogin.aspx is not setup to use intergrated Windows authentication or the authentication failed.
Another user has Enovia, but Aras plugin does not work. I just started at this company and first time being exposed to Ara and Catia.
Please help!
Hi chernandez1288,
If you are still having trouble with Innovator and Catia, I recommend contacting Aras Support ([email protected]). They will be able to help you troubleshoot the Windows Authentication configuration.
Eli
Eli Donahue
