I have an ItemType myDoc with a relationship myDoc_File to File.
I use Teams for the access rights to myDoc Items. Some of the users that are allowed to get a myDoc Item are not allowed to download the attached files (see the meta data is ok). I can hide the tab in the myDoc Form but that is not enough.
Is it possible to restrict the permission?
Ute
Hi Ute,
If you are still having this problem, then I recommend you use the Can Discover permission. Can Discover allows the designated Identities to see the items inside of a table or in a relationship of another item, but it does not allow you to open the item because that ability is given with the Can View permission. Therefore, I would create an Identity that would act as a group of people who can see the myDoc items, and only assign the Can View permission to that group.
Andrew
Andrew Johnson
Software Engineer for Aras Labs
