From looking at the code, it appears that this method should run correctly. Is this the full code of the method? Is this method intended to be called from an Action or a Server Event?
I'm really struggling with this Chris, Here is my entire method that I'm running from a server event, I also tried to run it directly from the method (Action/Run Server Method)
// *** Delete Related ID Components within MIN_Delivered_BOM
Item TDC_BOM = this.newItem("MIN_Delivered_Component","get");
TDC_BOM.setProperty("dpas","Remove");
TDC_BOM = TDC_BOM.apply();
List<string> TDCIds = new List<string>();
for (int v=0 ; v<TDC_BOM.getItemCount() ; v++){
Item dcBom = this.newItem("MIN_Delivered_BOM","delete");
dcBom.setAttribute("where","[MIN_Delivered_BOM].related_id = '"+TDC_BOM.getItemByIndex(v).getID()+"'");
CCO.Utilities.WriteDebug("deleteRelated", String.Format("{0} : DCid",TDC_BOM.getItemByIndex(v).getID()));
dcBom.apply();
// *** Delete Source ID Components within MIN_Delivered_BOM
Item TDC_BOM2 = this.newItem("MIN_Delivered_Component","get");
TDC_BOM2.setProperty("dpas","Remove");
TDC_BOM2 = TDC_BOM2.apply();
List<string> TDC2Ids = new List<string>();
for (int u=0 ; u<TDC_BOM2.getItemCount() ; u++){
Item dcBom2 = this.newItem("MIN_Delivered_BOM","delete");
dcBom2.setAttribute("where","[MIN_Delivered_BOM].source_id = '"+TDC_BOM2.getItemByIndex(u).getID()+"'");
CCO.Utilities.WriteDebug("deleteSource", String.Format("{0} : DCid",TDC_BOM2.getItemByIndex(u).getID()));
dcBom2.apply();
// *** Delete the Delivered Component
Item dcItem = this.newItem("MIN_Delivered_Component","delete");
dcItem.setAttribute("where","[MIN_Delivered_Component].dpas = 'Remove'");
dcItem.apply();
return this.getInnovator().newResult("Delivered Components and its BOM's have been deleted");
This is what my data looks like in SQL:
innovator.MIN_DELIVERED_COMPONENT
ID DPAS
7D5A81BA1B5B4B3CB5D287F1D60CF034 Remove
5786D96D44234DF39414767D63AED498 Remove
D92E1F0187E34319B170BE1AA6F96D0C Remove
630BAF3A500E49A9A1AC99CD17E3374C Remove
innovator.MIN_DELIVERED_BOM
id RELATED_ID SOURCE_ID
26B39DDFD3B0493F8EEFBAB445F59C42 5786D96D44234DF39414767D63AED498 7D5A81BA1B5B4B3CB5D287F1D60CF034
2E4484C0412F4FBCBDB5F501E4BC9AA3 630BAF3A500E49A9A1AC99CD17E3374C 7D5A81BA1B5B4B3CB5D287F1D60CF034
5D17CD0BBA8340EFB7B7032F895D3911 D92E1F0187E34319B170BE1AA6F96D0C 5786D96D44234DF39414767D63AED498
id SOURCE_ID RELATED_ID
5D17CD0BBA8340EFB7B7032F895D3911 5786D96D44234DF39414767D63AED498 D92E1F0187E34319B170BE1AA6F96D0C
26B39DDFD3B0493F8EEFBAB445F59C42 7D5A81BA1B5B4B3CB5D287F1D60CF034 5786D96D44234DF39414767D63AED498
2E4484C0412F4FBCBDB5F501E4BC9AA3 7D5A81BA1B5B4B3CB5D287F1D60CF034 630BAF3A500E49A9A1AC99CD17E3374C
Thank you for the additional code. I've tried testing this exact Method in a test environment on my machine, but I wasn't able to reproduce the Not a single item error that you are seeing. There could be another Server Event on one of these ItemTypes line an onBefore/onAfterDelete that could also be throwing this error.
Could you try adding a debugger to your Method and stepping through the code to see what line is causing that error? You can do this by following the steps below.
