I've been trying unsuccessfully to replicate functionality of a multilevel BOM report using a custom itemtype before implementing any changes in production tables. I have the following structures:
xBOM - a table with BOM items
xBOM Child Rel - a RelationshipType listing next lower assembly parts for BOM items, source: xBOM, Related: xParts
xParts - a table with standard parts
Getting a Report to cycle thru the BOM isn't working, only receiving one level down from any given BOM item.
Attempt 1:
<Item type="xBOM" action="GetItemRepeatConfig" select="part" id="{@id}">
<Relationships>
<Item type="xBOM_Child_Rel" select="related_id,qty"/>
<Item type="xParts" select="related_id,part,title" repeatProp="related_id" repeatTimes="6"/>
</Relationships>
Attempt 2:
<Item type="xBOM" action="get" id="{@id}" select="part">
<Relationships>
<Item type="xBOM_Child_Rel" action="get" select="related_id,qty">
<related_id>
<Item type="xParts" action="get" select="part,title" order_by="part">
<Relationships>
<related_id>
</related_id>
</Relationships>
</related_id>
</Relationships>
Suggestions?
The standard Multilevel BOM Report is built off of the Part->Part BOM->Part relationship structure. Because Parts can be linked directly to other Parts, you can end up with a potentially infinite number of levels to the relationship structure.
The data structure described doesn't seem suited to the same kind of Multi-level report since it appears to only allow for one level of relationships from xBOM to xParts. Could you clarify if there's a missing link from xParts to xBOM that would allow this structure to continue for multiple levels?
