\Innovator\Client\Modules\aras.innovator.core.MainWindow\deepLinking.js
in your code tree. Around line 24 you can add an additional snippet of code to close the window if an Innovator instance is already open.
if (!deepWindowIframe.src) {
deepWindowIframe.src = 'deepLinking.aspx';
window.close(); // Close this window if Innovator is already open
Please note that this proposed change was made in 11.0 SP15. You may require a similar workaround in a different file if you are using an older version of Aras Innovator.
Is there a way to avoid the helper window in 12.0 yet? We're on 12 SP9, and I keep running into that old problem of "if the linked-to item has previously been opened, the link works just fine, otherwise it fails"
