Server Method working when given a GUID, but not when using this
When I run this server method from the method itself and use a GUID to get the Item I want to update the method works fine, but when I change it from a GUID to = this; and run it from the  Item Type on the server events "OnBeforeUpdate" it crashes the whole server and the server has to be restarted.
// Item KSAAsses = inn.getItemById("smc_KSA_Assessment","2956D6CFB25949D39985FF112F2395FA");
Item KSAAsses = this;
Has anyone ever ran into something similar?
I can post more code if needed.
Thank you for your help!
Parents Reply
  • In context of OnBeforeUpdate method you can change "this" any way, but you can't use this.apply() or perform any actions that will result in an this item being written to the database because it will trigger OnBeforeUpdate again.
    When you inside OnBeforeUpdate you inside some upper "apply" already. So just change properties of "this" and return this. All your changes will be applied calling code.
Children
No Data
