AML Script to Check for Two or More Released Revisions of the Same Document Number
Can someone help me search for all documents that have more than one released revision? I found a couple of these and I need to check to see if there are more of them and the document numbers.  Is there an AML script I could use?
Parents
  • Try this
    <Item action='get' type='Document' select='item_number,keyed_name'>
      <config_id condition='in'>select CONFIG_ID from innovator.DOCUMENT where STATE='Released' group by CONFIG_ID having COUNT(*)>1</config_id>
    You need to temporary add  the
    <operating_parameter key="parse_item" value="false"/>
    to InnovatorServerConfig.xml to disable the AML secutity restrictions on the "condition='in'" expression.
  • I get this error...
    <SOAP-ENV:Envelope xmlns:SOAP-ENV="">schemas.xmlsoap.org/.../">
      <SOAP-ENV:Body>
        <SOAP-ENV:Fault xmlns:af="">www.aras.com/InnovatorFault">
          <faultcode>SOAP-ENV:Server.ItemAnalysisException</faultcode>
          <faultstring><![CDATA[Item Analysis Error. Some Items have incorrect attribute/property values syntax. See details for more information.
    Details:
    Incorrect value: "<config_id condition="in">select CONFIG_ID from innovator.DOCUMENT where STATE='Released' group by CONFIG_ID having COUNT(*)&gt;1</config_id>". Incorrect value explanation: "select" forbidden in property condition.
    ]]></faultstring>
          <detail>
            <af:legacy_detail><![CDATA[Item Analysis Error. Some Items have incorrect attribute/property values syntax. See details for more information.
    Details:
    ]]></af:legacy_detail>
            <af:exception message="Item Analysis Error. Some Items have incorrect attribute/property values syntax. See details for more information.&#xD;&#xA;Details:&#xD;&#xA;Incorrect value: &quot;&lt;config_id condition=&quot;in&quot;&gt;select CONFIG_ID from innovator.DOCUMENT where STATE='Released' group by CONFIG_ID having COUNT(*)&amp;gt;1&lt;/config_id&gt;&quot;. Incorrect value explanation: &quot;select&quot; forbidden in property condition.&#xD;&#xA;" type="Aras.Server.Core.ItemAnalysisException" />
          </detail>
        </SOAP-ENV:Fault>
      </SOAP-ENV:Body>
    </SOAP-ENV:Envelope>
  • Incorrect value explanation: "select" forbidden in property condition.
    Add the
Reply Children
