How can I wait for the result of aras.evalMethod when the called Method opens a dialog?
Hi community,
I have a custom button inside Form that leads to a custom Method.
This Method calls a second client Method with aras.evalMethod.
The second Method does a few checks and then opens a "confirm" dialog. User have to press OK or cancel the dialog.
The overall concept works fine, but I cannot get a valid result of the aras.evalMethod call. The second Method shall return the result of the selected dialog option. But the first Method doesn´t wait for the result of the second Method. So my result will be empty / undefined.
First Method
const args = "";
const result = aras.evalMethod("MySecondMethod", document.thisItem, args);
if (typeof result == "object" || result === false)
    return;
alert(result); // We immeditelly get this alert after the Method call. It will be empty, as the dialog it self wasn´t resolved yet.
// Other code, e.g. hide a button
const el=document.getElementById("myelement");
el.style.visibility = "hidden";
Second Method
window.ArasModules.Dialog.confirm(message, dialogOptions).then(
function(res)
    switch (res)
        case 'ok':
            dosomething();
           return true;
        default:
           return false;
I tried using promises and async/await. But so far aras.evalMethod never waited for anything.
I could merge the two Methods, but currently the second Method is called from multiple contexts. So this is something I want to avoid if possible.
Does anyone has an idea that could work to improve the situation?
Thanks!
Parents
  • Hi Angela,
    I was able to get this working by returning the promise from the second method in this example, i.e.:
    return window.ArasModules.Dialog.confirm(message, dialogOptions).then(
    function(res)
        switch (res)
            case 'ok':
                dosomething();
               return true;
            default:
               return false;
    I could then handle the result of this promise in the first method by adding a `.then` statement to the aras.evalMethod call, i.e.:
    aras.evalMethod("MySecondMethod", document.thisItem, args).then((result) => {
            return;
    This isn't a perfect solution in that it does require changing the second method to return a promise which may interfere with how it's being used elsewhere. Let me know if this works for your use case though.
  • Hi Chris,
    this worked perfectly!!! I did tons of tests with promises, but I never came to the idea of just returning the whole window itself.
    Thanks for the fast help! It saved me a lot of work :).
Reply Children
No Data
