Hi community,
I have a couple of custom Federated ItemTypes and TOC views that I designed many years ago for certain data renderings. Some of them are very old and I don´t even know if anyone still use them.
I either want to update the views to more modern UI and coding standards OR delete them if they aren´t needed anymore.
What’s the best way to find out which ItemTypes are being used?
I want to avoid to make a "survey", cause we all know how that ends: The users who matter won’t answer, and the rest will just get confused.
My favorite solution: User select certain elements in the TOC -> a new System or server log entry will be created.
Unfortunately the limiting factor for my favorite solution is the current used Innovator 12SP7. The TOC in this EOL version isn´t CUI based yet. CUI would make the task much easier to solve.
I want to avoid to customize the TOC logic in the codetree just for this use case. How would you solve this task?
Thanks for any idea!
