How can I get source of source identity if I know the child identity but not aware of numbers of parent? AML
How can I get source of source identity if I know the child identity but not aware of numbers of parent? need AML ..
I have tested GetItemRepeatConfig but it is going child level not reverse.. need help.
<AML>
<Item type="Member" action="get" repeatProp="source_id" repeatTimes="2" select="source_id(keyed_name)" >
<related_id>
<Item type="Identity" action="GetItemRepeatConfig" select="name" id="3EF5B0E5FAEF4716BF5F0A864B4C2239">
</related_id>
</AML>
Parents
  • <AML>
    <Item type="Member" action="get" select='source_id(keyed_name),related_id'>
    <related_id>3EF5B0E5FAEF4716BF5F0A864B4C2239</related_id>
    </AML> but not working as expected only working one parent label.. Advance Thanks
  • Hello  ,
    Do you mean that you want to find out which identity groups the 'Innovator Admin' user belongs to?
    For example, if the user is a member of the following identity groups:
    • All Employees
    • Authentication Administrators
    • Data Administrators
    Then you need the names of all such identity groups.
    Suhas
  • if yes then it may help you :
    <AML>
    <Item type="Identity" action="get" select="keyed_name">
    <Relationships>
    <Item type="Member" action="get" select="source_id">
    <related_id>
    <Item type="Identity" select="name" id="DBA5D86402BF43D5976854B8B48FCDD1">
    </related_id>
    </Relationships>
    </AML>
  • Hi  ,
    I would like to thank you first. I have completed that task by server side and calling it in client side method.
    I wanted the AML like child->parent->grandparent etc if i know or put the child id then it would have iterated towards parent. If we want to iterate from parent to child then it is like:
    <AML>
    select="related_id,name"
    id="BC72C6DE3D0F46D195711994B3993CA7">
    <Relationships>
    <Item type="Member" action="get" repeatTimes="0"
    repeatProp="related_id"
    select="related_id"></Item>
    </Relationships>
    </AML>
    But, my requirement was reverse. Okay Thanks a lot for your help Blush  ..
    Ananta
  • Hello  ,
    <AML>
    <Relationships>
    <related_id>
    </related_id>
    </Relationships>
    </AML>
    this query gives you all the parents, in this case Innovator Admin is present in as member of below group identities (as a child) then it will gives you all these identities (parent).
    • All Employees
Reply
  • Hello  ,
    <AML>
    <Relationships>
    <related_id>
    </related_id>
    </Relationships>
    </AML>
    • All Employees
Children
No Data
