I am trying to send Email, in my case I have document object which has one property called "Last Date",and I run workflow for the same, so I want to send mail before 1 day of "Last Date" property value, so is it possible to achieve it? or how can achieve this?
also How to configure SMTP?
at the time of installation I keep it as queue, so is there any guide to configure SMTP to send mail.
Hi Maddy,
If you are an Aras subscriber, I would recommend checking out the Aras Scheduler Service to schedule a daily check on the "Last Date" property on your documents. The use case you've described is similar to the sample provided in the Aras Scheduler Service documentation.
If you are not an Aras subscriber, you can create a custom server method to check the "Last Date" property and send emails when the "Last Date" meets your criteria. You can execute this method via a manual action, or you can create an external service/program that will periodically execute your custom method via AML.
Eli Donahue
