Component Engineering install failed
Former Member
Former Member
Hi , I tried to install component Engineering on a fresh install of aras innovator 11 sp9. I get an error. install path c:/Program Files (x86)\Aras\Innovator\Innovator server url localhost/innovatorserver Database InnovatorSolutions username admin passsword xxx aras update log says 2017-08-07 17:54:15,642 [8] INFO Aras.Tools.ArasUpdateGui.Logger Checking package started: 'C:\ProgramData\Aras\ArasUpdate\CE\11.0.1321\package.config' 2017-08-07 17:54:15,696 [8] INFO Aras.Tools.ArasUpdateGui.Logger Checking package finished 2017-08-07 17:54:15,789 [8] INFO Aras.Tools.ArasUpdateGui.Logger Installation of the package started : 'CE' from 'C:\ProgramData\Aras\ArasUpdate\CE\11.0.1321' directory 2017-08-07 17:54:15,823 [8] INFO Aras.Tools.ArasUpdateGui.Logger CompatibilityPackage started 2017-08-07 17:54:16,669 [8] INFO Aras.Tools.ArasUpdateGui.Logger Checking module 'IS' compatibility. 2017-08-07 17:54:16,811 [8] INFO Aras.Tools.ArasUpdateGui.Logger LoadFile started 2017-08-07 17:54:16,812 [8] INFO Aras.Tools.ArasUpdateGui.Logger Loading File : 'C:\Program Files (x86)\Aras\Innovator\Innovator\Client\scripts\include\rev.inc'. 2017-08-07 17:54:16,813 [8] INFO Aras.Tools.ArasUpdateGui.Logger LoadFile finished 2017-08-07 17:54:16,891 [8] INFO Aras.Tools.ArasUpdateGui.Logger LoadFile started 2017-08-07 17:54:16,892 [8] INFO Aras.Tools.ArasUpdateGui.Logger Loading File : 'C:\Program Files (x86)\Aras\Innovator\Innovator\Client\scripts\include\build.inc'. 2017-08-07 17:54:16,892 [8] INFO Aras.Tools.ArasUpdateGui.Logger LoadFile finished 2017-08-07 17:54:16,975 [8] INFO Aras.Tools.ArasUpdateGui.Logger Custom started 2017-08-07 17:54:16,976 [8] INFO Aras.Tools.ArasUpdateGui.Logger Custom check the property : 'Version.Check'. The value : 'true'. 2017-08-07 17:54:16,977 [8] INFO Aras.Tools.ArasUpdateGui.Logger Custom finished 2017-08-07 17:54:16,980 [8] INFO Aras.Tools.ArasUpdateGui.Logger Checking module 'DB' compatibility. 2017-08-07 17:54:16,981 [8] INFO Aras.Tools.ArasUpdateGui.Logger Application started 2017-08-07 17:54:17,064 [8] ERROR Aras.Tools.ArasUpdateGui.Logger Invalid URI: The format of the URI could not be determined. 2017-08-07 17:54:17,065 [8] INFO Aras.Tools.ArasUpdateGui.Logger CompatibilityPackage finished 2017-08-07 17:54:17,066 [8] ERROR Aras.Tools.ArasUpdateGui.Logger Aras.Tools.ArasUpdateCore.Implementations.Commands.CheckCompatibilityPackageCommand: Invalid URI: The format of the URI could not be determined. 2017-08-07 17:54:17,072 [8] INFO Aras.Tools.ArasUpdateGui.Logger Operation 'Install' failed best regards
Parents
  • Former Member
    Former Member
    Hello, I made the installation of Aras Innovator and we want to update MPP and QMS but we are presenting the following problem: 2018-02-14 10:41:07,107 [5] INFO Aras.Tools.ArasUpdateGui.Logger Checking package started: 'C:\ProgramData\Aras\ArasUpdate\MPP\11.0.1005\package.config' 2018-02-14 10:41:07,110 [5] INFO Aras.Tools.ArasUpdateGui.Logger Checking package finished 2018-02-14 10:41:17,710 [5] WARN Aras.Tools.ArasUpdateGui.Logger String[] {Incompatible version of Innovator} 2018-02-14 10:41:19,485 [5] WARN Aras.Tools.ArasUpdateGui.Logger Incompatible version of Innovator 2018-02-14 10:41:19,485 [5] ERROR Aras.Tools.ArasUpdateGui.Logger Aras.Tools.ArasUpdateCore.Implementations.Commands.CheckCompatibilityPackageCommand: Incompatible version of Innovator 2018-02-14 10:41:19,485 [5] INFO Aras.Tools.ArasUpdateGui.Logger Operation 'Install' failed I appreciate if you can help me with the solution of this problem.
Reply
  • Former Member
    Former Member
Children
No Data
