Contents : administration and My Innovator - only see contents
Former Member
I only see Contents: administration and My Innovator after I have logged in to this application.
What is wrong?
I should also see Contents:
Change Management
Cloud Services
Dashboards
Design
Documents
Portfolio
Source
Templates
Finally, where could I find an installation instruction (which work), so I can install this application on my local client for investigate this Innovator tool.
My tanks for all support.
There are two databases that are shipped with the standard Aras Innovator 11.0 installation.
Core110 - Contains only the Core Innovator ItemTypes (e.g. Permission, ItemType, File)
CoreAndSolutions110 - Contains both the Product Engineering and Program Management solutions which contains ItemTypes like Part, Document, Project, etc.
Based on your post, it appears you have restored the Core110 database instead of the CoreAndSolutions110 database. Please look for the /DB/ folder in your installation directory to find the CoreAndSolutions110 database. Please try to restore this database using this guide, and confirm if you still can only see the Administration and My Innovator folders.
In regards to your second question, you can find the installation guide as well as additional documentation for the service pack you are using here.
______________________________________
