Not able get value using RequestState
オフライン
Hi, I have created one method called set_project_name in VB and run this method on OnAfterLock of "GRIL Project" ItemType
Dim inno as Innovator = Me.getInnovator()
Dim projectID as String = Me.getID()
Dim AML_to_getProjectName as String = "<AML>"+
 "<Item type='GRIL Project' action='get' select='_project_name'>" +
 "<id>"+projectID+"</id>" +
 "</Item>" +
 "</AML>"
Dim ResultProjectName as Item = inno.applyAML(AML_to_getProjectName)
Dim projectname as String = ResultProjectName.getItemsByXPath("//Result/Item[@type='GRIL Project']").getProperty("_project_name").ToString()
 RequestState.Add("projectname", projectname)
Return Me
and I want that value on other ItemType called Document on the event called "OnAfterAdd" like this:
Dim projName As String
projName = DirectCast(RequestState("projectname"), String)
Return Me
  But I got the Null Object. Whether It is possible to get RequestState value on another ItemType?   Thanks in Advance. Regards, Maddy.
