Error: Variable 'Component Engineering' should not exist in the DB
We're getting this error when trying to install Aras Component Engineering : Aras Innovator Database Updates
2018-06-04 12:45:06,228 [7] INFO Aras.Tools.ArasUpdateGui.Logger Checking package started: 'C:\ProgramData\Aras\ArasUpdate\CE\11.0.1321\package.config' 2018-06-04 12:45:06,241 [7] INFO Aras.Tools.ArasUpdateGui.Logger Checking package finished 2018-06-04 12:45:06,260 [7] INFO Aras.Tools.ArasUpdateGui.Logger Installation of the package started : 'CE' from 'C:\ProgramData\Aras\ArasUpdate\CE\11.0.1321' directory 2018-06-04 12:45:06,267 [7] INFO Aras.Tools.ArasUpdateGui.Logger CompatibilityPackage started 2018-06-04 12:45:06,274 [7] INFO Aras.Tools.ArasUpdateGui.Logger Checking module 'DB' compatibility. 2018-06-04 12:45:06,280 [7] INFO Aras.Tools.ArasUpdateGui.Logger Application started 2018-06-04 12:45:06,307 [7] INFO Aras.Tools.ArasUpdateGui.Logger Variable 'VersionServiceUpdate' is found in DB.The value : '0'. 2018-06-04 12:45:06,313 [7] INFO Aras.Tools.ArasUpdateGui.Logger Application finished 2018-06-04 12:45:06,319 [7] INFO Aras.Tools.ArasUpdateGui.Logger Application started 2018-06-04 12:45:06,345 [7] INFO Aras.Tools.ArasUpdateGui.Logger The innovator DB contains AML package with name : 'com.aras.innovator.solution.PLM'. 2018-06-04 12:45:06,352 [7] INFO Aras.Tools.ArasUpdateGui.Logger Application finished 2018-06-04 12:45:06,360 [7] INFO Aras.Tools.ArasUpdateGui.Logger Application started 2018-06-04 12:45:06,385 [7] WARN Aras.Tools.ArasUpdateGui.Logger String[] {Variable 'Component Engineering' should not exist in the DB.} 2018-06-04 12:45:06,392 [7] INFO Aras.Tools.ArasUpdateGui.Logger Application finished 2018-06-04 12:45:06,397 [7] INFO Aras.Tools.ArasUpdateGui.Logger InnovatorDependence started 2018-06-04 12:45:06,403 [7] INFO Aras.Tools.ArasUpdateGui.Logger Required version of Innovator : '11.0 SP9'. 2018-06-04 12:45:06,430 [7] WARN Aras.Tools.ArasUpdateGui.Logger String[] {Incompatible version of Innovator} 2018-06-04 12:45:06,436 [7] INFO Aras.Tools.ArasUpdateGui.Logger InnovatorDependence finished 2018-06-04 12:45:06,442 [7] INFO Aras.Tools.ArasUpdateGui.Logger InnovatorDependence started 2018-06-04 12:45:06,449 [7] INFO Aras.Tools.ArasUpdateGui.Logger Required version of Innovator : '11.0 SP11'. 2018-06-04 12:45:06,479 [7] WARN Aras.Tools.ArasUpdateGui.Logger String[] {Incompatible version of Innovator} 2018-06-04 12:45:06,486 [7] INFO Aras.Tools.ArasUpdateGui.Logger InnovatorDependence finished 2018-06-04 12:45:06,492 [7] INFO Aras.Tools.ArasUpdateGui.Logger InnovatorDependence started 2018-06-04 12:45:06,498 [7] INFO Aras.Tools.ArasUpdateGui.Logger Required version of Innovator : '11.0 SP12'. 2018-06-04 12:45:06,524 [7] INFO Aras.Tools.ArasUpdateGui.Logger InnovatorDependence finished 2018-06-04 12:45:06,534 [7] WARN Aras.Tools.ArasUpdateGui.Logger Variable 'Component Engineering' should not exist in the DB. 2018-06-04 12:45:06,541 [7] INFO Aras.Tools.ArasUpdateGui.Logger CompatibilityPackage finished 2018-06-04 12:45:06,547 [7] ERROR Aras.Tools.ArasUpdateGui.Logger Aras.Tools.ArasUpdateCore.Implementations.Commands.CheckCompatibilityPackageCommand: Variable 'Component Engineering' should not exist in the DB. 2018-06-04 12:45:06,556 [7] INFO Aras.Tools.ArasUpdateGui.Logger Operation 'Install' failed
  • Hello, What version of Aras Innovator are you using? You can find this by opening the Help > About window from the main grid. Additionally, it seems you may be running into an issue where the Aras Update tool thinks that Component Engineering is already installed. Could you check under Administration > Variables and search for a variable named Component Engineering? Chris
