Server Error in '/InnovatorServer/Client' Application.
Root element is missing.
Description: An unhandled exception occurred during the execution of the current web request. Please review the stack trace for more information about the error and where it originated in the code.
Exception Details: System.Xml.XmlException: Root element is missing.
Source Error:
The source code that generated this unhandled exception can only be shown when compiled in debug mode. To enable this, please follow one of the below steps, then request the URL:
1. Add a "Debug=true" directive at the top of the file that generated the error. Example:
<%@ Page Language="C#" Debug="true" %>
or:
2) Add the following section to the configuration file of your application:
Note that this second technique will cause all files within a given application to be compiled in debug mode. The first technique will cause only that particular file to be compiled in debug mode.
Important: Running applications in debug mode does incur a memory/performance overhead. You should make sure that an application has debugging disabled before deploying into production scenario.
Stack Trace:
[XmlException: Root element is missing.]
System.Xml.XmlTextReaderImpl.Throw(Exception e) +88
System.Xml.XmlTextReaderImpl.ParseDocumentContent() +1087
System.Xml.XmlLoader.Load(XmlDocument doc, XmlReader reader, Boolean preserveWhitespace) +185
System.Xml.XmlDocument.Load(XmlReader reader) +134
System.Xml.XmlDocument.Load(String filename) +146
Aras.Web.Configuration.ServerConfig.GetXmlConfigInternal() in E:\Builds\Innovator_RELS11-0-SP12\6920-RELS11-0-SP12\Innovator.git\CompilableCode\Aras.Web.Configuration\ServerConfig.cs:213
Aras.Web.Configuration.ServerConfig.ParseXmlConfig() in E:\Builds\Innovator_RELS11-0-SP12\6920-RELS11-0-SP12\Innovator.git\CompilableCode\Aras.Web.Configuration\ServerConfig.cs:263
Aras.Web.Configuration.ServerConfig.GetServerConfig(String cachedInstanceKey, CreateNewInstanceRT createNewInstance, Object[] parameters) in E:\Builds\Innovator_RELS11-0-SP12\6920-RELS11-0-SP12\Innovator.git\CompilableCode\Aras.Web.Configuration\ServerConfig.cs:63
Aras.Client.Core.ClientConfig.GetServerConfig() in E:\Builds\Innovator_RELS11-0-SP12\6920-RELS11-0-SP12\Innovator.git\CompilableCode\Aras.Web.Client\ClientConfig.cs:48
ASP.default_aspx.init_application() +41
ASP.default_aspx.__Render__control1(HtmlTextWriter __w, Control parameterContainer) +54
System.Web.UI.Control.RenderChildrenInternal(HtmlTextWriter writer, ICollection children) +260
System.Web.UI.Page.Render(HtmlTextWriter writer) +39
System.Web.UI.Control.RenderControlInternal(HtmlTextWriter writer, ControlAdapter adapter) +79
System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +4124
Runtime Error
Description: An application error occurred on the server. The current custom error settings for this application prevent the details of the application error from being viewed remotely (for security reasons). It could, however, be viewed by browsers running on the local server machine.
Details: To enable the details of this specific error message to be viewable on remote machines, please create a <customErrors> tag within a "web.config" configuration file located in the root directory of the current web application. This <customErrors> tag should then have its "mode" attribute set to "Off".
<!-- Web.Config Configuration File -->
<configuration>
<system.web>
<customErrors mode="Off"/>
</system.web>
</configuration>
Notes: The current error page you are seeing can be replaced by a custom error page by modifying the "defaultRedirect" attribute of the application's <customErrors> configuration tag to point to a custom error page URL.
<configuration>
<system.web>
<customErrors mode="RemoteOnly" defaultRedirect="mycustompage.htm"/>
</system.web>
</configuration>
Is it correct that the InnovatorServerConfig file is empty during a new installation?This is not expected behavior. It sounds like Innovator did not install correctly. I recommend that you uninstall Aras, make sure you have IIS and other required components installed on your server (.NET Framework 3.5 and 4.0 or higher, ASP.NET, etc), and try installing Innovator again. Eli
