Hi everyone...
1.I have created "new ItemType". drive.google.com/open
2.I try to create instance of my "new ItemType". drive.google.com/open
3.After created "new ItemType" , I just reopen the created one. drive.google.com/open
In third image you see the ItemType “id” as header.
Can I change the “id” with “name” which is user entered text as header?
Hi...
I have understood my problem little bit.
If the name is unique then it will appear as header.
Now, How can i set a property at my ItemType "Unique"?
If set a property as unique i face an issue like "Column 'name' in table 'DOCS1' is of a type that is invalid for use as a key column in an index. Could not create constraint or index. See previous errors. in SQL: ALTER TABLE [DOCS1] ADD CONSTRAINT un3792 UNIQUE(name, [aras:uniqueness_helper])"
Thank you.
Sathishkumar C.
For the desired behavior, please go to the "Just Ask Innovator" help and type "keyed name" in the search, you will see how to set the right information to replace this ID by a readable name.
