Login page fails
Former Member
Former Member
Hi, I have installed SP14, it works fine in our Dev environment. But when after installing it on the test environment (same os, windows 2016 IIS 10), after entering username & password,  the error saying Status code: 404, Reason: "Not Found" Request uri: localhost/.../Authenticate.aspx The file does exist in the folder. So I found the log file, and indicates it cant connect to the ArasInnovatorAgent service, saying there is no endpoint listening at localhost:8734/ArasInnovatorAgent that could accept the message. The errors in the log are below: * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * 2018-07-16 15-14-44 Exception In Main Thread Request Url: sac202.lmal.com.au/.../DBList.aspx Request File Path/innovatorserver/Server/DBList.aspx User Host Address: 192.168.153.124 User: Is Authenticated: False Authentication Type: Thread Account Name: IIS APPPOOL\Aras Innovator AppPool ASP.NET 4.0 Post data: Connection:close Accept:*/* Accept-Encoding:gzip, deflate, br Accept-Language:en-US,en;q=0.9 Cookie:ASP.NET_SessionId=2pikcgoe0qviiwefgt50g3zc Host:sac202.lmal.com.au Referer:sac202.lmal.com.au/.../login.aspx User-Agent:Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/67.0.3396.99 Safari/537.36 Exception source: mscorlib Exception type: System.Reflection.TargetInvocationException Exception message: Exception has been thrown by the target of an invocation. ---Stack trace--- at System.RuntimeMethodHandle.InvokeMethod(Object target, Object[] arguments, Signature sig, Boolean constructor) at System.Reflection.RuntimeMethodInfo.UnsafeInvokeInternal(Object obj, Object[] parameters, Object[] arguments) at System.Reflection.RuntimeMethodInfo.Invoke(Object obj, BindingFlags invokeAttr, Binder binder, Object[] parameters, CultureInfo culture) at System.Reflection.MethodBase.Invoke(Object obj, Object[] parameters) at System.Web.Util.ArglessEventHandlerProxy.Callback(Object sender, EventArgs e) at System.Web.SessionState.SessionStateModule.CompleteAcquireState() at System.Web.SessionState.SessionStateModule.BeginAcquireState(Object source, EventArgs e, AsyncCallback cb, Object extraData) at System.Web.HttpApplication.AsyncEventExecutionStep.System.Web.HttpApplication.IExecutionStep.Execute() at System.Web.HttpApplication.ExecuteStepImpl(IExecutionStep step) at System.Web.HttpApplication.ExecuteStep(IExecutionStep step, Boolean& completedSynchronously) ----- Inner exception Exception source: mscorlib Exception type: System.ServiceModel.EndpointNotFoundException Exception message: There was no endpoint listening at localhost:8734/ArasInnovatorAgent that could accept the message. This is often caused by an incorrect address or SOAP action. See InnerException, if present, for more details. ---Stack trace--- Server stack trace: at System.ServiceModel.Channels.HttpOutput.WebRequestHttpOutput.GetOutputStream() at System.ServiceModel.Channels.HttpOutput.Send(TimeSpan timeout) at System.ServiceModel.Channels.HttpChannelFactory`1.HttpRequestChannel.HttpChannelRequest.SendRequest(Message message, TimeSpan timeout) at System.ServiceModel.Channels.RequestChannel.Request(Message message, TimeSpan timeout) at System.ServiceModel.Dispatcher.RequestChannelBinder.Request(Message message, TimeSpan timeout) at System.ServiceModel.Channels.ServiceChannel.Call(String action, Boolean oneway, ProxyOperationRuntime operation, Object[] ins, Object[] outs, TimeSpan timeout) at System.ServiceModel.Channels.ServiceChannelProxy.InvokeService(IMethodCallMessage methodCall, ProxyOperationRuntime operation) at System.ServiceModel.Channels.ServiceChannelProxy.Invoke(IMessage message) Exception rethrown at [0]: at System.Runtime.Remoting.Proxies.RealProxy.HandleReturnMessage(IMessage reqMsg, IMessage retMsg) at System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke(MessageData& msgData, Int32 type) at Aras.Server.Agent.Proxy.IInternalAgent.CheckVersion(String serverVersion) at AgentService.AgentServiceHelper.Startup(IInternalAgent agent) in E:\Builds\Innovator_RELS11-0-SP14\7022\Innovator.git\CompilableCode\Core\AgentService\AgentService.cs:line 125 at AgentService.AgentServiceHelper.InvokeAgent(Action`1 action, String agentServiceEndpointAddress, Int32 timeoutSeconds) in E:\Builds\Innovator_RELS11-0-SP14\7022\Innovator.git\CompilableCode\Core\AgentService\AgentService.cs:line 81 at Aras.Server.Core.InnovatorGlobal.Session_Start() in E:\Builds\Innovator_RELS11-0-SP14\7022\Innovator.git\CompilableCode\Core\HttpApplication\InnovatorHttpApplication.cs:line 59 ----- Inner exception Exception source: System Exception type: System.Net.WebException Exception message: Unable to connect to the remote server ---Stack trace--- at System.Net.HttpWebRequest.GetRequestStream(TransportContext& context) at System.Net.HttpWebRequest.GetRequestStream() at System.ServiceModel.Channels.HttpOutput.WebRequestHttpOutput.GetOutputStream() ----- Inner exception Exception source: System Exception type: System.Net.Sockets.SocketException Exception message: No connection could be made because the target machine actively refused it 127.0.0.1:8734 ---Stack trace--- at System.Net.Sockets.Socket.DoConnect(EndPoint endPointSnapshot, SocketAddress socketAddress) at System.Net.ServicePoint.ConnectSocketInternal(Boolean connectFailure, Socket s4, Socket s6, Socket& socket, IPAddress& address, ConnectSocketState state, IAsyncResult asyncResult, Exception& exception)
