Demo: Modeling Examples in Aras Innovator
Tired of Vanilla PLM?  Need to adapt your PLM environment to fit you business processes?
Come to our special year end demo series webinar and see examples of modeled solutions in Aras Innovator.  You will see how the Aras Model Based SOA allows you to increase your team's efficiency.
The demos will illustrate a number of real use cases and include a panel discussion to share information and ideas. Please join us for the final demo series of 2016 and get some great ideas for 2017.
Note: we are allotting 90 minutes to give ample time for demo and discussion. Participants may need to leave but may still submit questions for the discussion.
You can register for this event HERE
Presenters:
A new way to visualize Aras data: a Graph Viewer
Benjamin Chaillon, Minerva
minerva
Developed for Airbus, this Graph extension on top of Aras Innovator allows end users to visualize data as oriented graphs for a better understanding of the data and the relationships between them. Easy and friendly interface, filtering capabilities, and discover mode.
Contact Info: [email protected]
use Innovator core functionality and custom API's to display items and manifestations to users
Vijay Kannan, Aras
aras_logo_300
This demo will help customers who wishes to implement a complete system for managing their entire product information management process. Customers who has the need to classify their information based on Model, Series and Line can benefit from this solution approach. The solution is designed to be scalable and maintainable with minimal code modifications.
Add and Remove Affected Items on an In Work Change
Dennis Lindinger, Razorleaf
razorleaf
Sometimes a change process requires additional affected items to completely implement the change. Depending on the state of the change, it may not be possible to add additional affected items, so a second change is started. This solution will allow additional affected items to be added to the change and have all of the same business rules applied as if it were on the change from the start. The solution also works for removing affected items.
Dynamic Workflow Assignments
Terry Quan, EbD Advisors
ebd-advisors
When a customer needed the ability to change workflow assignments after initialization of the workflow process we created a custom solution to manage the business process. We modeled a custom workflow process behaviors so that changes to the Team assigned to the Controlled Item would be reflected in future assignments within that specific workflow process.
BOM Editor
Graham McCall, AESSiS
aessis
Making changes to multiple levels of a product structure can be time consuming. To increase efficiency we created a BOM Editor that gives you the ability to manipulate and edit all levels of a multi-level BOM simultaneously in a single interface.
